I am hoping someone can help me diagnose the actual problem here. I'v had 3 plumbers in and each one gave a different diagnoses, and rather then spend loads of money on replacement parts I may not need I thought I'd try the forum for advise.
a few weeks ago we noticed that thr radiators are not getting hot, or when they do they don't stay hot for very long even if the controller CH is set to "on"
futhermore whilst I've been trying to investigate this i've noticed that the pump is running continuesly even when CH and HW are "off" at the controller. I can manually move the 3 way switch from auto to Manual but most of the time my radiators do not get hot.
I've noticed the pipes to the pump and to the boiler are generally hot when the system has been on for a short while, it seems the boiler Termostat reaches temerature very quickly ( moving the dial from 3 to MAX it does not click anymore unless the boiler has been off for a while )
so it seems the boiler gets hot quickly causing it to stop heating the water. the pump runs 24/7 but my radiators stay cold.- yet it seems i do have HW. today I let the system cool down, by truning it off at the wall for a few hours, then turning it on ( the boiler was cold) the pump kicked in straight away. the 3 ways switch was in mid position. my radiators got hot/warm for about 15 minutes and the cooled down again, and my boiler stopped heating the water but the pump just carries on
I have a standard pumped open vented system with a potterton boiler, and room thermostat and 3 way valve switch with 10mm Microbore themostat controlled radiators
current diagnoses have been:
faulty boiler PCB
faulty pump
faulty 3 way switch
pipes clogged needing powerflush
I have a spare pump which I could swap out but it occured to me the water in the tank is getting hot so the pump must be working
very confused, any help greatly appreciated
faulty boiler PCB
faulty pump
faulty 3 way switch
