Hi, I fitted a new hw tank before chrismas along with new 3 way motorised valve, tank stat and timer control box. There is a stat on the hw tank but no room stat.
All has been working fine until recently. The heating and hot water are set to come on in the morning but when the water reaches temperature the heating then stops aswell, the indicator light on the control unit is still lit but the circulation pump stops and the boiler goes out. to get it running again I have to set both to off and then pull the fuse and reinsert it and then put heating and water back on to the timed setting.
What do you reckon? Take the control box back and swap it for new or could it be somoething else?
The control box is a Gasslin Towerchorn QE2.
Thanks, James.
Thanks, James.
