Hi all,
I hope you can help! I had my boiler and pump replaced a week ago - new ones are Ideal Logic Max Heat2 H24 and Grunfos UPS4 GO. All seemed OK when it was installed (in place of an old, still working boiler and pump). However, each day the heating refuses to work. Often when it comes on the radiators are stone cold, or tepid at best. I have had the plumber back several times and he seems baffled. Every so often it starts to work normally for no apparent reason and without touching anything (after maybe 6 hours of running and not distributing heat to the radiators). But then when the room thermostat cuts out, when it turn back on the radiators don't warm up and the room temperature slowly drops.
We have tried various settings on the pump with no reliable success. Often a change makes it start to work but the next day we are back to stone cold. One strange thing is the power at the pump, even when on setting 3, can vary from 5-10W to over 40W when the system isn't working properly.
Boiler is set at 65C which seems to be plenty high enough when the system works.
House is a large bungalow (extended) with 11 radiators, mostly double ones. The control valves are Honeywell V4043H for the hot water and radiators. Expansion tank in loft. The TRVs were changed at the same time - most were over 20 years old and some starting to leak where the control pin is. Other than that, all other pipework is the same, except for some shuffling of pipes to the boiler so they were in the right place for the feed/return.
Any suggestions as to what the problem could be or things to try? I though maybe an air lock somewhere but the plumber thinks not.
TIA.
TIA.
