Heating problem radiators downstairs don't come on!
6 Sep 2013
We have recently moved into a rented house. With it being summer we have only just looked at the heating and when we turn it on only the upstairs radiators come on. Not very technical myself but it is a water tank in one of bedrooms with a control for the water and heating in there as well. Is this something we are doing wrong or do I need the landlord out. Better ask now so we have heat for winter the speed they get things done haha
Cheers
I would have thought the landlord is your best bet as (s)he would be likely to know how the system works or if it doesn't then they are there to get the repair sorted right away.
A lot more info would be needed before anyone here would be able to advise.
If you turn all the upstairs rads off do the downstairs ones heat up? If not the system could be zoned, so you might have a seperate thermostat for upstairs and downstairs. As you are renting I would just tell the landlord your problem and then it is his responsibility to fix it
Ok it's got a grundfos super electric pump...
None of the radiators can be turned on or off the white knobs on them do not turn. We asked the landlord how heating n water worked when first moved in but she didn't know which is a little odd to me...
I'll ring em n ask thanks for the replies was just wondering
Use an adjustable spanner and turn the valves off by turning the spindle on the lockshields clockwise after you have removed the white caps. Then turn the heating back on and it should clear what sounds like an air-lock; there will be some gurgling noises then hey presto.
If that doesn't work, time for a plumber.
Sorry but this is the landlord's problem and you should not be messing with it, especially if you have no knowledge of plumbing or the system setup. Insist (s)he gets it sorted asap
