Hi, I'm new to this forum & hope I have posted in the correct place.
I have a large 12m X 4.40m garage, in fact it is 2x garages joined together, of wooden construction 2"x3" beams covered with wooden cladding, one half roofed with corrugated tin, the other fibre type corrugated.
I am at present dividing them back into 2 separate sheds, replacing the central wall, to use one half as a workshop/office for my computer business. This will be rewired, insulated, lined with plaster board & a ceiling installed.
I want to raise the 2”x3” trusses, which run across the width of the building to about 20cm from the walls at each end, to increase the ceiling height. If I raise these up to the next beam up on the roof, I will gain 28cm, which is adequate for the purpose of the job.
When divided the workshop area will be 5.5metres in length, 4.4 metres wide, with a ceiling height of 2.18metres high. There are 3 trusses which need to be heightened. Is this possible, or is there a set out calculation which limits this?
I can supply pictures & further information if required.
Regards
Dave.
Regards
Dave.
