help- grill ignitor constantly clicking
17 Sep 2007
Lincolnshire
My built in parkinson cowan has a main oven and seperate grill, the grill ignition constantly clicks unless it is lit- when lit it stops- even if the grill is off and closed it clicks unless i switch the mains off- this is a realpain as i have to have the grill on to put anything in the oven,
when the grillis lit if the door is closed it huts off the gas an continues clicking.
Can anyone please please help?
Rob
Could be two things possibly sticking switch on control knob spindle for the grill ignition or fauly spark generator
gas- the ignitor only clicks when the gas is off, when the grill is lit it stops- any ideas? i dont mind taking it to bits to have a look but am not sure where to start- there is a light that shows when the grill is on- this is constantly lit as well so i assume its a sensor or switch- jus not sure where to look
Theres no model given, but behind the fascia on the gas tap spindle there is usually a micro switch the contacts could be welded shut so its on all the time when the grills on it rectifys as it should so it stops.
Posting model no might help !
sorry- i did post the model in another post but that one went unanswered- its a parkinson cowan module 4:4000 built in oven & grill
if it was on the spindle how would it dtop when the gas is actually on? would some pictures of the unit hep you to help me diagnose it?
Thanks for all your help!
