Worcester Green Star Heatslave 12/18 oil fired combi.
Will not fire up. Plenty of oil in tank, in Tigerloop and at bleed point. When it's turned on at the mains with demand for heating and hot water the pump can be heard spinning. Lock out light is NOT on, however when pressing the reset button(under the front panel) there is no sparking noise, not sure if it should or not??. The only thing that has occurred is that the water pressure had dropped to '0' and I didn't notice, I normally have to boost it up every two months or so, forgot to check with the holidays and all that!! Could this have triggered a reset switch somewhere??
Thanks in advance, Dave
