Dear All,
Would be extremely grateful for any help you could provide:
We recently moved into our new home which is a flat which is 15 years old. Boiler (Potterton Suprima) is in the kitchen and hot water tank, central heating pump and expansion vessel in cupboard.
One night boiler was just not working - called out engineer who said it had developed an air lock and fixed it.
After that noticed pressure had started to drop and needing filling once a week - called a nice gas safe engineer who felt that the AAV was leaking and replaced it. Also noticed pump was not working well and replaced that.
Unfortunately the pressure is still dropping and still needing to top up once a week - original gas safe engineer not contactable and called another guy out who had no idea.
The central heating pump is working fine. Put a bag over the expansion vessel pressure relief pipe and no water there after 24 hours. No obvious leaks from any of the radiators or pipes.
Any suggestions/tips would be much appreciated.
S
S
