- Joined
- 27 Jan 2008
- Messages
- 29,464
- Reaction score
- 3,618
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I am also had problems the first few I did with a moulded breaker what do you enter as “Type” there is no B, C or D so I entered MB which thinking back was not really enough info. I would enter % of rated current it is set for and note “See manufactures data sheet” now. We are also told the measure the Line / Neutral impedance but there is nowhere to enter results.
Most the questions you ask are found by inquiry, which in real terms means copy them from last certificate issued. This in commercial premises should be available so one can see a trend. However we all know domestic premises tend to have lost any paperwork that existed 10 years ago.
So in real terms we either enter it as code 3 as we are not permitted to remove fuse to check what it is or we guess. I would enter code 3. So would look something like below.
BS, Type “Code 3” No of poles “3” Current rating 100A Voltage rating “400V” Location “What ever” Fuse rating or setting “less than or equal to100A” (Would use sign but may not work on forum. Likely fuse is BS 3036 but we don’t always know. I take normal voltage as being U on three phase supply and Uo on single phase supply.
2-phase, 3-wire is where two phases are brought in from a three phase supply and 1-phase, 3 wire is where a single phase is split 230 – 0 – 230 so U = 460 volt not 400 volt but people living in towns may never see a 1-phase, 3-wire system these tend to be farms etc.
I think it’s better to say don’t know than guess so I would put code 3 but other I have seen guess what it is likely to be.
I use IET forms and they are not perfect but are near enough and can’t see anyone can object to them. If you use any other versions the questions may be different the IET has explanation to the forms I would hope all others do the same.
I may not be doing it right but no one that matters has complained.
Eric
Eric
