help needed radius radiator
29 Sep 2008
hi does anybody know how to work out the radius of a radiator. this radiator is going to be fitted in a 1930,s bay window
You will need to make a template of the bay out of cardboard or a bit of old carpet so that the rad can be made to fit. Just giving the radius is not a good idea as the bay might not be a perfect curve.
Could be very expensive if you get it wrong.
thanks for your quick reply, i will try that ,do you know anywhere that bends the rads
One other VERY IMPORTANT POINT is that the template needs to be of the wall surface, not the skirting as the rad will hang on the wall.
