Hi - as I'm sure will quickly become apparent, aside from the basics, I know very little about plumbing! Therefore I am appealing to you beautiful, full of wisdom, people (flatter flatter) to help with a strange (or maybe not) problem.
The overflow from the cold tank in my loft has been dripping for some time. Not constant, but a few hours every day. On inspection it looked like the original ballcock/valve is still in place (50 years old), but, rather than replace, I thought I'd change the washer. - stripped out, changed washer, replaced. No problem.
However, it made no difference to the dripping - rats...
Finally I went the whole hog and replaced the ballcock/valve last weekend. Simpler job than I thought it would be and I was quite chuffed with myself. However (and here's the rub) THE OVERFLOW IS STILL BLEEDIN' DRIPPING!
The new ballcock/valve is functioning perfectly - not dripping at all on shut off, and the level that it shuts off appears to be a good few inches below the actual level of water in my tank - so the only thing I can think of is that water is entering the tank somewhere other than through the ballcock/valve. This is where I show my ignorance...
Is this possible? Where is it coming from? & How do I sort it out?
Any help gratefully received and appreciated
