Help Remove Old Valve
4 Nov 2011
London
Hello
Can anyone help.
This valve is very old and seized and I am trying to replace it.
I cannot use a wrench as I cannot get purchase on the nut as the other pipe is too close. I note that my 17mm is a bit too small, can anyone hazard a guess what spanner size I will need?
Also I am assuming this valve is very old, is there a modern valve (maybe 50 years) that will replace it in terms of size or won't that be a problem?
Thanks alot View media item 48150
2 pr of good quality glandnut plyers should do the job.
Is it the incoming mains, and can you turn it off elsewhere.
Dig around it. Pipe slice or hack saw. Then replace the whole valve.
Job done. Don't mess about with the old valve.
Its coming from the tank in the roof. So I can turn off the water from the main stop cock, where the water comes in from the road.
Do you think I will be able to find the same length of valve to replace this one , I don't want to get involved with pipe work etc.
No you'll have to cut the pipe and you will need a new piece of pipe.
Sounds like plumber time to me if you don't want to tackle piping.
