Hello Guys,
I know this is going to be a basic questions for some of you, but i had to start somewhere
I have 3 sets of wires. 1 set had a Black, red and earth wire. The other two sets both consist of a black and a red wire.
One set of wire controls the 1st hall light, the second controls the 2nd hall light and the 3rd set of wires control the outside light.
I have a 2G 2W switch. That has two switches on the front.
The problem is i can't get them all wired up so all 3 lights work. I think that the two hall lights are linked together.
This is how far i have got.
Top = C= black 2nd hall light. L1= Red 1st hall light. L2 Red 2nd hall light.
Bottom= C= black 1st hall light. L1=black outside light. L2 red outside.
With the above wired up. I get both hall lights on via one switch, the other switch operates the outside.
But one has to be off for the other to work?, well if the outside light is one, the hall lights just glow a little.
If i remove the outside lights wires, then both hall lights work fine.
Please can a kind sole advice me on wiring up this switch so all lights work as they should do?
Thanks in advance for any assistance.
svan
svan
