Help with Boilermate OV A-class
14 Dec 2018
Hello, I’m hoping someone might be able to help me with a situation I have regarding my hot water. As stated I have in my property a Boilermate OV A-class and Worcester boiler. The problems I’m having is the water temperature doesn’t seem to be getting hot enough, you notice this most in when trying to run a bath. You can solely run the hot tap and the water by the time it’s half filled is only lukewarm. This does also happen in the kitchen downstairs, and sometimes the taps upstairs as well. The taps are slightly more varied with how bad it gets but the bath is always the same. It is a mixer tap with shower hose attachment as well. I do also get problems with a shower on a different floor in the house when that will all of a sudden will run stone cold half way through a shower and then go back to hot enough again. After doing some internet research, a lot of threads talk about a mixer valve, but I cannot see one anywhere?? I’m Unsure also how you actually set the hot water temperature?? I gather you can also do some sort of fault scan on the Boilermate to test the sensors by the buttons at the top but with no instructions even this seems a bit risky for me to start pressing buttons and hoping for the best lol. Any help greatly appreciated.
Tim
P.s. The central heating system seems to be working as it should with the radiators working ok to the best of my knowledge.
These Boilermate’s didn’t have a mixing/blending valve on them like the earlier ones.
Do you get scale where you live? Possibly scaled domestic plate heat exchanger or a mixer tap somewhere in property faulty and passing cold water to all taps.
