Help with Mira Sport 9Kw Shower wiring
22 Feb 2013
Cornwall
Hi, can anyone help me.
Have removed the wires to check the thermal switch but while struggling to get the rear screw out the wires moved and got mixed up.
From what I can assume,
the thin brown (front)goes to the right terminal with the thick brown & thin black
the thick red & brown go to the left terminal
and the thick & thin blue with thin black go to the middle.
The screw which holds the switch doesn't have any wires connected and the green wasn't removed.
If anyone can confirm or correct me I will be very grateful indeed javascript:emoticon(':D'). The shower Is about 12 years old and gets used about 4 times a day every day if not more so has served us very well.
Martin
[/][/img]
Yes
Thin brown from solenoid coil at the bottom of shower.
Thick brown from the mains connector block.
Thin black from the power neon.
Yes
Thick brown/red from the 2 micro switches.
Thin blue from on/off button at the bottom of shower.
Thin black from power neon.
Yes
Yes
Thank you Seco, will have a go at putting it back together tomorrow. Stupid of me to forget to take a photo before I touched anything. Lesson learnt.
Cheers :D
