Help!!! Worcester 24i RSF
7 Oct 2008
Staffordshire
Hi
I have a worcester 24i RSF combi - yesterday I lost pressure, water leaked i think via auto air vent. No leaks anywhere else
I refilled system started the boiler boiler requested heat for CH - water now gushes out of the auto air vent boiler starts to kettle over heat stat trips water continues to pour out of auto air vent.
What as gone wrong? could the auto air vent be faulty, I've checked the CH thermistor reads 10 - 12K looks okay - I released the remaining pressure via air release valve to stop water pouring out - any help ideas appreciated -
Regards
Phil
From your description, it appears that the AAV could be scaled, therefore releasing water and air. Does the pump run?
i'm not sure about the pump - if it is its very quiet - i don't have time to take the front off to look at the shaft rotating before the water starts gushing out of the AAV - can i check it with no system pressure or reduced pressure just very briefly
Should the AAV not pass water at any time?
Is it okay to replace the AAV if the pressure is 0 bar as i can see no shut off valves for the CH return or flow.
Thanks for your help
