Hi can you help? lack of pressure
10 Jun 2011
Hi can anyone advise, we have a ideal HE30 isar boiler which is 3 years old its worked great until my husband removed a radiator to decorate the radiator leaked which he fixed now we have no pressure or water going round system hence no heating can anyone advise please
You have to repressurise. There is a "filling loop" which is a short section of (usually) flexible pipe connecting the cold water inlet to the heating loop. On older systems this was usually external and there would be a tap somewhere near the boiler. On newer boilers it is often internal and operated by a small tap or key under the boiler somewhere.
Turn the tap, key, or whatever is on your boiler, water comes in, pressure guage rises to just over 1, then turn off the tap.
we have tried that but theres no water getting through its just under 3 years old
i really appreciate the advice so far can you suggest anything else?
you should have something like this, you need to open both taps at the same time then you should hear the boiler start to fill.
my husband says we have to pipe you have shown but apparantly one tap opens but the other one doesnt
does it have 2 taps or is it one tap and just a chrome valve on the other end ?
Sometimes the plastic knob twists without turning the shaft. If so remove the nut and use an adjustable spanner.
Or get a new husband with plumbing skills.
Tony
i need a new husband in more ways than one.
thanks for advice
