Honeywell 3 port mid position y plan valve and actuator
10 Jan 2010
Hertfordshire
Hello please could somebody recommend me the honeywell valve I need.
I need a 3 port valve that heats hot water and heating at the same time. and also heats them individually.
Using the Sundial Y plan. Model numbers would be great.
Thank you.
V 4073 A 1039 usually the 22 mm version
Edited because I put VA for some reason
Assume its only the V4073 and that I put VA in error although I seem to have that in my head!
Tony
I still have the box! Its a V4073A 1039/U 22mm mid position valve. Ive put a link on your other thread if any use Spiceman?
