- Joined
- 6 Jan 2019
- Messages
- 25
- Reaction score
- 0
- Country
I have a Honeywell Galaxy GD48, with a mix of mostly wired zones but also a few RF zones. I recently bought a 4 button RF keyfob TCC8M but I can't get it to work very usefully which I suspect is because I have 2 groups set up. Group A1 is the house and group A2 is the detached garage. The garage is left full set the entire time that we're not using it, whereas the house is full set when we're out and unset or part set when we're in.
I learnt the keyfob and it is associated to a user.
When I press the "full set" button on the fob it simply makes the keypad go from the banner screen to the group set screen, so I can see which groups are currently set and I can then toggle between set and unset for each group on the keypad, and initiate a system set as that user for a group. Same behaviour for the "part set" button. When I press the "unset" button on the fob it unsets *both* groups.
This is not useful. Is there no way to initiate a full set, part set or unset on a specific group entirely from the keyfob? A double press, or hold down a second key? The instructions say that you can set up "programmable key combinations", but I cannot find any details of how you do that anywhere! I can't see anything obvious in the CODES menu 42.
Thanks,
Steve.
Thanks,
Steve.
