Hi. just found this neat forum.
Right I have checked the brushes and there are good continuity between brush end and the wire, plenty of life left in brush.
Have checked the clear tubing for any leaks leading up to the pressure switch (is it called this?)
Belt is fine.
It may be worth noticing that when this fault occurs it tripped the fuse. (fuse reset fine afterwards)
I am at a loss what next to check. Any idea anyone?
Belt is fine.
