ive had a good search on the forum and found that error code 1 could mean 3 different things , however the fault i get with the machine is
i can select any setting and put the machine to go , it then goes through half the cycle and the error code comes up so its seems like a drainage problem , i thought that this had to be the pump not extracting the water fast enough , so ive replaced the pump and checked for any blockages but i still get the same fault , im scratching my head here , anyone got any suggestions
cheers mike
cheers mike
