hoover quattro washer/dryer steam comes out when door opened
6 Jan 2005
Hi
I have had a look on the threads with regards to my fault and was wondering if there could be any other causes.
The washing after being on a drying cycle comes out very hot and not dry, also clothes have a stale smell and when the door is opened you can see steam coming out.
I have cleaned what I think is the condenser which goes to the fan and also to the back of the drum and the rubber hose and the plastic tube that I presume is the vent but still the problem exists.
Is there anything else to look for as to what is causing this.
many thanks
mark
faulty inlet valve on condenser ,check the 3 inlet valves ones open circuit
ROCKS1
Thanks for the info, I have checked this and the solenoid on the cold water inlet going to the condenser does not seem to be working as not letting any water through. although the other solenoid is still working OK so I would assume a new unit is required.
Thanks once again
oh yes needs replaceing try google or fleabay for part cost about 20 quid
