I have a Sime freindly combi boiler and its still giving me problems with hot water, ch is fine though. The water gets hot then goes cold then hot for a few minutes then cold again. In the last year ive had a new pcb(old one was burnt out), genuine theromcouple(non genuine would not work properly), divertor valve(stopped the hot water going to the rads instead of the taps), a radiator flush to descale/clean the system(water was barely mucky when rinsed out) and a new hw thermister (stopped the pilot light cutting out when you turn off bath taps), the gas pressure is fine and does not drop, the water flow is set to 10l per minute as per the instuction book. The fault finding guide says it could be a 'limit thermostat', am i likely to fix it with putting a new one in, the gas guy im using does not want to just keep replacing parts over and over untill hes basically fitted a new boiler part by part. Any ideas on what else it could be?
