Here goes...apologies for long windedness...
Moved in to new house (3 bed semi) in the summer. I am a First Time Buyer so never had to worry about Boiler and CH heating probs before.
Found out that water was being run off the immersion heater tank in airing cupboard in the main bedroom.
Told the most effective way to heat water was to use the combi (also weirdly installed in main bedroom) (only recently too) (had a carbon monoxide alarm in room too)
Boiler is Halstead - Hero
So switched off the immersion heater.
Have a timer control panel in the airing cupboard for CH & HW. This is set to TWICE for HW, once in morning and once evening.
The radiators in the house all have temp controls on the side, these have been all set to OFF/*
Turned these on a couple of weeks ago while it was cold one night.
Fine - all worked (bar the bathroom one but that just needed bleeding - working fine now)
Turned CH back to OFF as didnt need it any longer.
Then have begun to notice that radiators I have left on at the side on temp control are coming on when the HW comes on!!
Have noticed that this is the only when the HW comes on - thru Half Term last week noted that radiators weren't on during day.
NB. the radiator in the hall is warm during most of day - but presume this is because it is directly below airing cupboard. gravity and all that.
I have tried to turn the CH on and off and see if it makes a difference, tried advance, but haven't really noticed a change.
What do I do? Is there something I am not doing correctly?
Some sort of switch I am missing?
Or is it a valve at fault sending the hot water to radiators too.
Im a bit nervous of this as its my first house and would hate for it to be a major problem!!!
Thanks in advance guys
Gav
Gav
