Hi All I have a hot tap on a hand basin in our down stairs loo with a problem .For a while its been a bugger to turn off (theyre the smooth plastic types that are difficult to grip with wet hands and you always had to give it an extra twist) .Anyhow just before we went on hols I tightened it down to make sure it wouldnt be dripping while we were away .Come back off hols and although the tap opens its not working properly .if the tap is opened slowly nothing comes out .if you turn it on sharply you sometimes get a short burst of water and then other times it will turn on and run for about 30 seconds or so and the petre out . Is it airlocked if so all the suggestions ive had for clearing them wont work on theses taps as its impossible to put a hose over the ends and flush it with the cold or could it be the tap valve thats faulty ?
