Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
right sorry, well the neutral of the wall stat must go to the neutral terminal of the programmer thats a must, i take it no-one has moved wires in the wall stat
just read post again, you know when you say upstairs working ok boiler not what do you mean both water and central heating are dependant on the boiler so what is actually happening
i wire up central heating systems all the time for plumbers in my area and i just realised from your post that if you have a three port valve it will require inputs.
1 ch on, water only goes around rads
2 hw on water only goes around tank in airing cupboard
3 ch and hw on valve goes to the mid position waters goes around both
usually when ch on only you need the hw off terminal wired in so it may have well been used before
What you have to do is scrap it and start again. Your problem is the normal expoerience we have. The y plan system was never wired up correctly in it's life.
Without boaring myself to death a quick scan of what you have revealed tells me so.
You must do the work from the wiring centre beside the mid position valve.
Follow the Honeywel Y plan procedure and all will be well.
Warning, you may not have sufficient wires at present, your pump may be fed from your boiler with an overrun control, your room stat may or may not require a neutral. Assuming your mid position valve (the crux of the whole system) is in good condition starting again is the solution.
Someone like us who is used to wiring these could probably fauilt find it but you don't stand an earthly from the understanding you have demonstarted so far. That is not said to offend but to assure you of what a mamoth task lies ahead. It would take me about 2hrs to sort, when I did my first one it took a day.
