Hot Water Cylinder Lifespan
8 Aug 2011
Manchester
Wondering what is the general lifespan of an open vented conventional hot water cylinder?
Depends on quality of the water where I live and mostly work copper cylinders without a anode fitted 10 years if your lucky.
Been using stainless cylinders for some time
Also seems to depend if it has thermostat pockets. They seem to go through in 10 years.
The cylinder will last forever, but what's inside might not. Depends on the water to be honest.
my new cylinder has one of those
I have just had my second tank go that way. I have made a temporary fix and plan to braze a plate over the pocket and use external contact to operate the thermistor. Checking the internet I found that this was a common issue.
Thanks for the replies. It's probably around 50yrs old, copper, no thermostat pockets (probably weren't used then!) Was originally gravity feed, converted to fully pumped around 20yrs ago.
