hot water from overflow
16 Jun 2004
I have an open vented hot water system heated by a heat exchanger from the boiler. The heat exchanging system is venting into it\\\'s feed + expansion tank when hot water is swiched on at the timer (which I think it is supposed to?). The water is not being drawn away quickly enough (it is being drawn away as I can feel the other pipe moving) though and because of this it is going out through the overflow pipe. Any idea what could cause this?
PS.
The bottom of my f&e tank is level with the bottom of the cold water tank - they both sit on the same piece of wood. Hot water looks clean. Ball valve is dripping but only slightly - fixing this separately
Thanks,
PS.
Thanks,
:twisted: raise the expansion tank above feed
Boiler thermostat faulty
Coil in Cylinder broken and leaking
Ballvalve in Exp tank dripping
Pump speed to high
Blockage in System
Pump installed in correctly
