After installing my oil CH system using Danesmoor 15/19 I noticed the header tank in the loft was getting hot. Acting like another radiator. This problem is not so bad if I turn the pump down to 2 and not a problem at all if the pump is turned to 1 although at 1 the water distribution around the radiators is inadequate.
I spoke to a plumber who advised converting to a sealed system and running the pump at 3.
I posted on here yesterday to learn more about sealed systems and discovered they are not a panacea for all CH problems. In fact they can cause problems and do require regular maintenance/inspection.
Currently I run the pump at 2 and find the water in the header tank is just warm.
Is it unusual for water in header tanks to warm up?
Have I fitted the pipework incorrectly?
Does warm water in the header tank warrant the work & expense of converting to a sealed system?
Mike
Mike
