- Joined
- 13 Feb 2018
- Messages
- 19
- Reaction score
- 0
- Country
Firstly, apologies if this is in the wrong area of the forums.
I've just had a new Viessmann Vitodens 100 30kw boiler fitted on LPG, the CH is not fitted yet with only one small radiator as the load.
Problem is, DHW is at the upper end of warm, after 5 minutes of running the water, I can comfortably hold my hand under the water.
I've checked CH loop pressure and it is just over 1bar, flow rate is good and hot water temp setting on the boiler is max at 60 degrees.
Any ideas?
Any ideas?
