Valiant EcoTec plus 831 boiler (located upstairs).
Boss Therm BPS242RF thermostat (located downstairs)
Receiver for the thermostat is a BR1 (Think it is Siemens)
The thermostat is either set to Night time or Day time, never the timer.
The thermostat is showing a low temperature in the hall and the UP sign that shows it is requesting the CH (central heating) to come on
The receiver is showing GREEN and AMBER lights on (this means power , connected to transmitter and received the request to fire CH)
However the boiler does not fire up for the CH to come on.
If you turn any hot tap in the house the boiler will come on and provide hot water.
This seems to be an intermittent issue. I had a boiler man check the boiler but as is the way it fired up and worked 30 minutes before he arrived!
The thermostat and receiver are getting on and are no longer available. Looking to replace with EPH CP4 as this should do what we need.
The pressure is showing as 1.7 bar and in the green.
Any suggestions gratefully received.
