Hi All,
I have had a potterton puma 80e for about 10 years, it has always been covered by heat team.
About eight weeks ago, i turn on the bath tap and the hot water flowed for about 2 minutes then the boiler blocked out.
I checked that the water preasure dial was ok and added a small amount of water, then pressed the reset and the boiler fired again.
I waited a few minutes and tried to fill the bath again but it locked out again after about one minute.
I called in heat team and the guy said i needed a new DHW Temperature Sensor, while he was fitting it he said that I had cold water mixing somewhere in my system and that i should check the shower or other mixer taps.
Since that time I have fitted pegler shut off valves to the hot and cold supply to the first floor,
It still cut out, The only other tap is a sink mixer so I put another pegler valve on the cold side of that mixer.
I was pig sick when it cut out yet again, I had thought that this was not the cause but had to find out the hard way that this guy had it wrong.
Obviously I need to call them in and prove that its not the mixing thats causing the problem it was only a slight dribble I could pee faster..
Anyone got a possible solution?
Sorry for the long story guys!
Dave
Dave
