Hello chaps,
I am trying to answer a very basic question put forward to me by a friend in need. He has a 3 bedroom property, with modern indirect water system. i.e. water tank up in the loft, and a hot water cylinder etc.
He says that when both showers are in operation, the hot water seems to run out and takes ages to re-heat. We all know this is inevitable, but what would an ideal fix be for this problem. I mean can you change the hot water cylinder to a far more efficient one, to reduce waiting times when water does run out. Or could an electric water heater be added somewhere along the system?? Im a trainee electrician by trade and am slowly learning a thing or two about plumbing, the above situation is very common in nowadays homes, but what is the ultimate solution?
Thank you in advance.
