System is [I think] open vented,baxi bermuda back boiler.
Problem arose after gas board changed the meter? He switched off the gas at boiler then relit after meter change but set thermostat control on boiler to max.
Later same day the system vented very hot water out of overflow into the feed and expansion tank resulting in it appearing in bathroom!
Tried turning the boiler stat down to position 2 [where it should have been] but now system will not ignite beyond pilot light unless I put the thermo control to the '0' position then it will boil the system again as the full flame remains constant and doesn't cycle as it did previously -any ideas please?
