The hot water has stopped working properly in my flat. These are the recent circumstances...
- no hot water one morning last week.
- Landlord sent out his plumber/handyman bloke
- same fella had installed a brand new boiler about 3 months ago when a v.small leak was noticed with the previous one
- fella came to the conclusion that it was the electric timer settings panel that was faulty so replaced it with a new one.
- plumber set up the new timer settings so we'd have hot water at times we needed it. Set it to come on and then came back an hour later to check we had hot water, we did so success.
- but the timings set didn't produce hot water the next morning when we woke up.
- had a play around and tried different combinations of timings, none work.
- only way to get hot water is to press the 'boost' button which basically heats the water for an hour and gives about a showers worth of hot water in 50ish minutes.
Being useless at any kind of DIY I've come to the basic conclusions that...
Its obviously not the boiler as we can get hot water
Its the timer panel thing not working. The red light comes on at the right times we set it too but it just isn't heating the water.
Before I call the landlord again tomorrow is there anything simple I'm missing?
The timer thing...
The boiler/heater itself...
If you need any other info then please ask.
The timer thing...
