Hi
We have an Ideal Mini 25 combi boiler, and have had no problems over the winter while the heating and hot water have both been on.
Now, when we switch it to hot water only, it is fine for a while, but then overnight it seems to stop working. In the morning there is no hot water (boiler doesn't fire when you turn the tap on).
In order to get it working again we have to switch it back to heating, wait for the boiler to fire up, then switch it back to water, and from then it is fine for a while.
We thought at first that it only did it overnight because that was the longest it went without being used, but we are out during the day as well, and I don't ever remember having problems when I get home from work in the evening. It only seems to do it overnight - most mornings, if the heating has been switched off the previous day, there will be no hot water.
The radiators have all been bled, and the pressure seems OK. Boiler is located in an outside cupboard.
My first thought after reading this forum was the diverter, but it seems weird that it only does it overnight. Some kind of weird frost protection??? (But it's not that cold anymore!)
Any suggestions would be welcome!
