Noticed the boiler was running for long periods during summer, checked motorised valve, working OK, cylinder thermostat working when water goes cool, however, it seems the thermostat will not switch off at the required temp.
What I have tried
Ran the bath to empty the hot water
Set the cylinder thermostat to 50.
Boiler kicks in and runs for 4 hours.
Turned the cylinder thermostat down until it clicks and cuts out the boiler, but then the cylinder thermostat won't click on until it hits 65 (full on).
The boiler does eventually go off so the thermostat must work at some point.
The hot water is always ON at the controls and has been since we moved into the new house 3 years ago.
Is there a better way to check the thermostat please.
What I have tried
