absolute novice so bear with me...my baxi combi boiler is great with central heating..but hot water is very poor..i have to run the bath at the slowest trickle you can which takes forever..however if something like the washer fills at the same time my bath water goes icy cold..or even if i up the speed of the bathwater it will quite quickly go cold....
is there a bleed pipe on the actual boiler
does pressure status affect the water temperature
thank you in anticipation from a very cold bather!!!!!!!!!!!!!!!!!!!!
