My problem is
- the washer will start a cycle (k programme), then perhaps 10 minutes in stops with the 'Drying High Heat' light flashing (slowly), and also the on/off light flashing (rapidly).
-I have dissassembled the filter at the bottom and cleaned it out (20p richer, wahoo!)
-I've also blown down the pipe at the drum which drains into the filter to check the (pressure switch?) isn't blocked.
Any ideas what this error code might mean?
I did see a list of error codes. But I wasn't sure which way the lights are numbered.
Is the 'Drying High Heat' lamp at the top lamp 1 or lamp 5?
And what would these lights flashing represent?
Rob
Rob
