hotpoint aquarius WML760p 7Kg model door glass replacement
27 Nov 2011
Lancashire
Hi I need to replace broken door glass on this machine, how do you split plastics to put new glass in, and will door have to be removed.
On the inner door trim should be 5 holes , in them holes are screws. Them the door trim splits to change the glass.
Thanks rock1, only 3 holes with screws in, others look like blind holes, I suspect there are clip forms holding it together, will have to be brave and try prising it open.
any more suggestions welcome, and thanks for reply
John
Some have 3 some 5. Yes it just clips together then slides over the handle. Some are clipped by the door hinge as well
