Hi All. Went to use the washing machine today and find it wont switch on all all after finishing the last load a few days back without any noticeable problems.
No lights at all are coming on and it is as if it was unplugged from the mains.
I've given the wiring and boards a quick look over and cant see any blown or damaged components at first glance. I can also confirm that the washing machine has power going into it (tested at the main power module located at the bottom rear righthand side with a 240volt test light)
Can anyone suggest what the likely fault may be and if it is a job that can be done without having to call out the Hotpoint guys to connect a laptop to?
Thanks for your assistance
