Hotpoint BFI620 - new pcb fitted but now LED 2+3 flashing
15 Dec 2011
Essex
Hope someone can help. My dishwasher was stopping after an hour with LED 4 flashing. Searching loads of posts lead me to the conclusion that the heater was at fault so I replaced it - problem remained. Further searches pointed to the pcb and when I looked at it there was clearly some burn out damage.
So I replaced the pcb, being careful to get the right one (C00143206). I managed to get the test cycle running although the instructions I got are quite unclear. It ran for about 30 minutes and then appeared to stop with lights 2+3 flashing. From other posts, I believe that indicates a time out on fill, and when I checked carefully the inlet hose was a bit kinked. So I unkinked it and went to re-run the test cycle but I can't make anything happen at all. The lights just flash whatever button I press.
The instructions suggest it's possible to reset the cycle by holding the P button until you get three beeps but that just doesn't work. I've switched it off at the mains for 15 minutes but when I turn it back on the lights are still flashing and no amount of button pressing can get it to do anything.
Any idea what's going on?
Ian
