Hi, have recently had problems with my hotpoint ctd40. The empty water light was flashing after a minute or so of the cycle, even though the tray was empty. I have taken the pump assembly out from the back and took apart. I found a red rubber impeller had been damaged and was off the plastic spindle. I assume this is probably the problem, but could someone please confirm this, and if the impeller is available to buy without buying a new pump.
Thanks John
Thanks John
