Hotpoint D/W DWF50 stops with LED 6 flashing mid-cycle
14 Jul 2008
Fife
I'm having a problem with my Hotpoint dishwasher where it stops late in the cycle and flashes LED 6. The machine is always empty of water when I open it.
I read elsewhere that this is a 'heating timeout' issue, but I have checked the element for continuity and it's okay according to my multimeter.
The water is always cold when I open the door mid-cycle. Could the element be on its way out?
Jon.
flashing 6 means ntc detacted ,remove front consol panel and outer door panel just on the tablet dispenser is a white block thats the ntc should be cliped to side of dispenser just refit it job done ps dont slam the door thats wot causeing it be come off :lol:
Hi again,
thanks for the suggestion, I removed all the insulation and everything was in place. I disconnected and reconnected the only connector that clipped into the side of the dispenser just for good measure. I'll stick it on for a fast wash and see what happens.
rocks1- thanks, although the thermistor was in place I couldn't find any other explanation for the flashing 'delicate' LED (number 6) and so replaced the PCB as I couldn't get a replacement thermistor seperately.
Everything working fine now and much cheaper than a Hotpoint service call.
Thanks for your help, it's much appreciated!
