Hotpoint Fault Code.
30 Jun 2008
Suffolk
Hi all, my son has a Hotpoint Aquarius and its showing fault code 'f06'.
The door won't open at present. Can anyone tell me what the problem is and will he need a service engineer. Ity is under parts and labour warranty until 2015.
See Below:
F06 indicates a faulty door lock or a fault on the electronics of the main board supplying power to the door lock.
Unplug the appliance.
Wait 10 minutes.
Give the handle a thump or two.
Try opening the door.
Does it open? If not:
This suggests the door lock has failed.
Hopefully it won't have damaged the main control board.
Take the top off.
Reach down inside and you'll find the door lock.
In the middle of it you should find the latch pin just poking through the door lock.
Try opening the door by pushing the latch pin over.
Or call out the insurance you have on it.
Andy
Thanks Andy. Will text my son tonight when I get home. Probably take advantage of the warranty call out as he is not electrically/mechanically adept unfortunately.
Much appreciated.
Andy, just to let you know, the first option worked and the door opened.
Thank you.
Should he still get a service engineer out or just see if it happens a few more times?
I would say get the service engineer out, he will probably fit a new lock. You know if you leave it then it will only break just before xmas when no one can come out until the new year.
Andy
