Hotpoint tdc30p tumble drier - not heating up
19 Oct 2011
Kirkcudbrightshire
Hello
I was hoping someone could help me out:
It wasn't heating up so I cleaned all filters and replaced both thermostats and the heating element - still no heat. I temporarily bypassed the thermostats but still no heat. I also noticed the "drying" indicator lamp is not illuminating.
Thanks in advance
Much appreciated Rocks1
Is the relay the clear(brown)plastic component positioned to the left of the heater selector and on off switches. (looking from the front of the dryer)
I don't want to throw too much money at the repair but it is now getting "personnal" :evil:
I will purchase one and give it a whirl - could it be anything else do you think while I'm ordering (to save on postage)
Many thanks for your help
Sorry I did forget to mention that the motor does work and doesn't cut out. It's just the heating process that doesn't work
No it's not that. The Pcb is in the top right hand corner , and on that is a relay box try and look for a dry joint on the Pcb , just go over it with a soldering iron otherwise a new Pcb is req. If you can match the relay from maplins / rs cost is penny's.
