hotpoint ultima CD85
14 Jan 2009
Hull
hi any one advise on this problem. Dryer light up all ok, set programme, press start and the eath leakage Breaker trips on the main fuse board, it will attempt to turn the drum for a split second.
everything else seems ok checked all usual
heater wet ,remove rear panel and dry with a hair dryer also clean condenser out and dry before fitting back
