hotpoint washer dryer
1 Jan 2011
Glasgow
i have a hoptoint aquarius washer dryer,model no is:WDL540p.
the dryer is not heating up,can anyone help ? thanks.
joe
heating element or one shot gone ,its on the heater box 2 brass screws for heater and a long yellow wire for one shot but test which one is faulty ith a meter
its a one shot fuse in the yellow wire .if the unit overheats it pops .
thanks
so i will have to buy a meter and test both fuse and heater ???
how do you test them with the meter ???
joe
put meter on ohms ,or get a continuity tester which is a bulb battery and a piece of wire .then if it lights up it works .
hi rocks
thanks for your advice,the bulb battery & wire.how do i use all of those & how do i connect it to the element.
regards,
joe
a continuity tester is made up of them parts remember your schools lessons .it tests a curcuit like fuses and bulbs , bit like a meter ,place wire and the other end of the tester on the fuse and then the heater , it lights up it works , google or a tester in maplins ebay or rs etc.
