hotpoint wd420 flashing lights
16 Jul 2010
Edinburgh
I know this has been asked before but it didn't fully asnwer my question.
The flashing light and 2 aand 4 which is full pressure (or something similar) the fix was to remove the filter clean it and replace it. I did this (the part with the large ball) and removed 31p LOL
I put it all back together and am still getting the same problem codes coming up.
Does this mean the pump is knackered or is something else afoot??
Many Thanks
Does it still pump out water. Is the waste pipe /sink spigot clear. Did you unplug it for 30 secounds to clear error. Check filter /pump again for more money. Is the impelor broken in the pump.
No the water does not pump out. It just sits there, waste pipe is deff clear. filter and pump all seems to be clear. I had a quick look inside the pump and all seems to be OK.
You still have a blockage does the pump hum when put on to pump out.
Nope no noise from pump. Rinse and Spin light comes on and then nothing.....then the lights 2 and 4 flash
Pump wire come off or pump gone open circuit.
When I was cleaning everything I had the pump out and it was all wired up etc etc. If I am honest it does appear to be ommiting(sp) a slight burning smell but I am led to believe most pumps and motors do.
What do you mean by an open circuit??
If you stick a continuity tester on the pump connections it should bleep if not pump burnt out by the coins. It has a themo cut out on the coil windings it might reset when cold. Try in the morning if no joy pump needs replacing.
Believe it or not I don't own a continuity tester... I have a volt meter thingy but thats it. Any other way of testing it??
I will try again in the morning and keep you updated.
Huge thank you for helping.
I will deff be staying around. Just moved into a place of my own (rented) but trying to keep costs down and help where possible etc.
Talk in the morning :D
Tried the machine again with no luck :(
Whipped the pump out and took it to a local spares place who sold me another one (brand new) for £25 which I didn't think was too bad.
Put the new pump in and wholah! We now have a working washing machine.
Thank you once again rocks1
remember the golden rule always check pockets otherwise it costs you money :wink:
LOL I don't do the washing so I am blaming the missus LOL
Again thank you and I am sure I will be sticking around when I/she breaks something else HE HE
