Hotpoint WD420 flashing lights
23 Sep 2011
Luton
Machine has suddenly decided to stop working (although still making noises) and start flashing at me instead. The local engineer says it needs a new motherboard but seems to have difficulty locating one - hence why I'm here.
The flashing lights are Drying High Heat/Reduce Creases/Time Saver and the On-Off. The machine is currently switched off at the plug as no response to the On-Off once it's flashing.
Checking one of the previous posts (http://www.diynot.com/forums/viewtopic.php?t=163622) indicates that these lights are:
f13 lights 1&2&4, dryer ntc/ fan motor - which doesn't mean a lot to me.
I bought the machine second hand but is this a simple fix and/or worth it?
Thanks in advance.
Regards,
new pcb required contact emw in nottingham for a recon 45.00 quid
PCB taken out - Mark4; ordered and delivered.
Replaced it this evening and put on a quick cycle.
Everything seemed to going well for about 1-2 minutes and then the flashing lights again; same as before: 1,2 & 4.
Ideas appreciated.
Thanks,
Edit: This did not resolve the problem!
Hi
I came across your old post, I have had the same problem.
1. Replaced PCB.
2. When the Machine is in off mode, it still switches on with flashing lights (fault F13 - lights 1,2 & 4 flashing).
My solution:
I tested the NTC Thermal limiter and it has a shot open circuit (no continuity)
I have ordered a new one from Hotpoint for approx £20.00
NTC Thermal limiter:
NTC Thermal limiter position
I am expecting the new part resolves the problem, as the F13 fault points to the Dryer NTC
